Switching regulated power supply circuit of Toshiba SD-K320 DVD player
Source: InternetPublisher:已注销 Keywords: DVD Toshiba regulated power supply circuit switching regulated power supply Updated: 2020/12/29
Shown is the switching regulated power supply circuit of Toshiba SD-K320 DVD player . As can be seen from the figure, it is mainly composed of AC input circuit
, rectifier filter circuit, switching oscillation circuit, switching transformer T802, secondary rectifier filter and voltage stabilizing circuit.
(1) AC input circuit
The AC input circuit is composed of fuse F801, mutual inductance filter T801, filter capacitors CSOI~C804, etc.
(2) Rectifier and filter circuit
After filtering the 220 V AC voltage, a bridge rectifier circuit composed of diodes D802~D805 and filter capacitor C805 performs rectification and
filtering , and then outputs a DC voltage of about 300 V and sends it to the ⑤ pin of the switching transformer T802 .
(3) Switching oscillation circuit
The switching oscillation circuit is mainly composed of JC803 and peripheral circuits. The oscillation circuit, voltage stabilization control circuit and switching field effect transistor
are all integrated in IC803 (S-IR-F6535). After starting up, the 300V DC voltage output by the rectifier of the 220V AC voltage is
added to the ③ pin of IC803 through the primary winding @~③ of the switching transformer T802, and the ◎ pin is internally connected to the drain of the switching transistor. At the same time as the power is turned on, the AC
input voltage forms a starting voltage through R804 and is added to the ④ pin of IC803, causing the oscillation circuit in IC803 to start oscillating, and switching
current begins to be generated in the primary winding of switching transformer T802.
The secondary windings ①~② of T802 will induce switching signals. The output of pin ② is formed by the rectifier and filter circuit to form a positive feedback signal and superimposed on
pin ④ of IC803, so that pin ④ has enough DC voltage to maintain the oscillation of the oscillation circuit in IC803, so that the switching circuit enters a stable oscillation
state.
(4) The secondary rectifier output circuit
T802 has multiple windings, and the output end of each winding is connected to a rectifier filter circuit, which outputs
voltages such as lo V, 6.6 V, Sv, 11.8 V, -24V respectively.
The error detection circuit is set in the +10 V output circuit. The voltage dividing points of R826 and R827 are the voltage sampling terminals. The sampling voltage is added to
the R input terminal of VT821. The photocoupler vr802 is connected to the C terminal of VT821. When the output voltage changes It will cause
the luminous intensity of the light-emitting diode in VT802 to change, which will cause the impedance between the collector and emitter of the photosensitive transistor in VT802 to change. The ③ pin of VT8Q2
is connected to the ① pin of IC803. Pin ① of IC803 is the input terminal of the voltage stabilizing negative feedback signal. This loop regulates the output voltage.
(5) Start/standby control circuit The
start/standby control signal from the microprocessor is added to the ① pin of the photoelectric coupler VT804. The oscillation
state of the switching power supply is controlled through VT804 to start and standby. In the standby state, the switching power supply is intermittent. oscillation.
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- ISO113 circuit that can reduce power consumption
- Single-power supply circuit for ISO122P/ISO124
- Use pulse width modulation to get a precise output voltage
- LED rechargeable flashlight circuit diagram
- Switching power supply circuit composition and function introduction of each part
- Parallel DC regulated power supply circuit diagram
- 0.7~24V continuously adjustable current limiting power supply
- Circuit diagram explanation: simple switching power supply circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- Characteristics and advantages and disadvantages analysis of switching regulated power supply
- Do you know about 600V small smart power devices?
- Switching regulated power supply circuit
- Switching voltage regulator circuit of Lesheng DVD-883E ultra-thin DVD player
- Toshiba GR-185E(A)(G), GR-235E(A)(G), GR-265E(A)(G) refrigerator circuit
- Toshiba GR-183E(G)(A), GR-203E(G)(A), GR-233E(G)(A), GR-263E(G)(A) refrigerator circuit
- 5V, 1A switching regulated power supply circuit
- Adjustable switching regulated power supply circuit diagram using LAS6351
- Series switching regulated power supply circuit diagram with output of 5V and 10A
- Half-bridge switching regulated power supply circuit diagram using SG3524
