Do you know about 600V small smart power devices?
Source: InternetPublisher:柯南道尔 Keywords: Toshiba power devices Updated: 2020/01/13
What is a 600V small intelligent power device? What does it do? Toshiba Electronic Components and Storage Corporation ("Toshiba") announced today the launch of a high-voltage intelligent power device (IPD) with model number "TPD4162F". The device is available in a small surface mount package and is designed for use in motor drives in products such as air conditioners, air purifiers and pumps. And plans to start shipping today.
TPD4162F product diagram
TPD4162F is manufactured using a new process and can reduce power loss by about 10% compared to Toshiba's current IPD product TPD4152F. This helps reduce overall power consumption in devices integrating the device.
TPD4162F has various control circuits, and the output stage is equipped with IGBT and FRD. It supports direct driving of brushless DC motors with square wave input signals from Hall sensors or Hall ICs without the need for a PWM controller IC. At the same time, its various built-in protection circuits also reduce peripheral circuits. In addition, the use of the HSSOP31 in a small surface mount package also helps reduce the size and height of the motor control circuit board.
application:
Brushless DC motors for electrical equipment
Fan motors (air conditioners, air purifiers, ventilation fans and ceiling fans, etc.)
Pump
characteristic:
?9?9 High voltage: power supply voltage (VBB)=600V
?9?9Low loss: rated output saturation voltage (VCE(sat))=2.0V (typ.)@IC=0.5A
FRD forward voltage (VF)=1.5V (typ.)@IF=0.5A
Small and thin HSSOP31 package: 17.5mm×11.9mm (typ.), t=2.2mm (max.). The above is the analysis of 600V small smart power devices. I hope it can help you.
- How to Make a Soft Latch Circuit
- In-depth analysis of DC-AC converter inverter
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Practical and convenient fax machine power supply control circuit
- ISO113 circuit that can reduce power consumption
- Parallel DC regulated power supply circuit diagram
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- CNC regulated power supply production
- Detailed explanation of mobile phone charger circuit diagram
- EPSON PHOTO 830U printer power circuit
- High current (4A) switching regulator integrated circuit L296 outputs 5.1 to 40V
- 3-phase CPU power circuit using HIP6301 and HIP6601 chips
- 2-phase CPU power circuit using HIP6302 and HIP6601 chips
- Single phase thyristor slotless nickel plated power circuit
- Warm current power circuit a
- Transistor stabilized current power supply circuit 2
- Additional power circuit design for USB devices
- Antenna amplifier synchronous power supply circuit
- Nine-speed adjustable DC power circuit
