DC parallel stabilized power supply circuit
Source: InternetPublisher:走马观花 Keywords: Regulated power supply circuit Updated: 2021/03/07
Shown is a DC parallel regulated power supply circuit used in the radio circuit . The AC 220 V voltage is stepped down by the transformer and outputs
8V AC low voltage. The 8V AC voltage outputs about 11 V DC through the bridge rectifier circuit, and then is filtered by CT. R , Ds voltage stabilization, C2 filtering and outputting
6V stabilized DC . Two electrolytic capacitors are used in the circuit for smoothing filtering.
Although the power supply circuit using a Zener diode for voltage stabilization is simple, its biggest disadvantage is that the Zener diode
still consumes current when the load is powered off. The smaller the load current, the greater the current flowing through the Zener diode, because this The sum of the two currents is equal to a constant. Therefore, this regulated
power supply is only suitable for situations where the load current is small and changes little.
- How to Make a Soft Latch Circuit
- Schematic diagram of car cigarette lighter to USB power port
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- LNK304 non-isolated LED light string driver circuit
- An ultra-low output voltage regulator
- Integrated regulated power supply with continuously adjustable output voltage
- CNC regulated power supply production
- Converting a lithium battery charging board into a constant voltage and current charger
- Reconstruction of the tube pre-stage by using low voltage difference power supply
- Practical constant current charger-----Constant current charger
- Voltage stabilization control circuit in power circuit
- FGDF-3 three-phase low-temperature iron-plated power supply circuit
- 300A-18V three-phase thyristor voltage regulating electrolytic power supply circuit
- Transistor stabilized current power supply circuit 2
- Diamond differential input power amplifier power circuit
- Low voltage adjustable reference power circuit
- DC power supply circuit for semiconductor radio
- Power circuit for home appliance repair
- Common power circuits and applications 09
- ±5V, ±12V power circuit A
