High Speed Dual Switching Regulator Circuit
Source: InternetPublisher:super_star Keywords: Switching regulator PWM Updated: 2021/06/21
Shown is a high-speed dual- channel switching regulator circuit, which is also commonly used in the inverter circuit of LCD displays. The
TL1451A chip is the core component of this circuit. In this circuit, the t power circuit supplies power to the @ pin of the chip. The oscillator ar PWM comparator
in the chip constitutes a PWM signal generation circuit.
It generates two PWM signals and is output by the @ pin and the @ pin respectively. The PWM signal output by the chip is amplified by the complementary push-pull amplifier to control
the output transistor t to change the power supply voltage into a pulse voltage, and then outputs a DC voltage through the LC filter. The output circuit uses a step-down type to output
a lower DC voltage. The output stage uses a boost type to output a higher voltage.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Schematic diagram of car cigarette lighter to USB power port
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Driving circuit of switching power supply field effect tube
- Energy-saving motorcycle rectifier regulator
- Step-down power supply for driving relays
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Transformerless AC-DC constant current LED driver circuit
- Adjustable regulated power supply with current limiting protection
- An ultra-low output voltage regulator
- Classification analysis of PWM control
- STR5412 power circuit
- 24V power supply pure flat display high voltage power supply circuit diagram
- Flash camera 6-channel power supply circuit (MAX1566-1567)
- Precise high current drive circuit
- PWM signal generation circuit diagram
- PWM300 to 1000W fully automatic emergency power circuit
- Switching regulator composed of TL431
- MC34063 and transistor form a high current boost switching regulator
- PWM circuit with clock
