GZ-600 argon arc welding machine circuit-03
Source: InternetPublisher:狂妄火龙果 Keywords: Electromechanical argon arc welding machine Updated: 2021/05/08
G2r600 argon arc welding machine is an AC arc welding machine that uses argon as a shielding gas
. The circuit is shown in the figure. The input power of welding transformer Ti is
103kV. A. The no-load voltage is 220V, the working voltage is 20V, and the welding current
adjustment range is 50-600A. The diameter of tungsten electrode is 1-6mm. The control circuit
can ensure that the electrode automatically delivers argon within 1 to 2 seconds before arc ignition, and
automatically stops argon within 8 to 15 seconds after the arc is extinguished. A high-frequency oscillator is used for arc ignition. After arc ignition, the welding transformer is automatically connected and the welding current is automatically cut
off. When no-load, the welding power supply is automatically cut off and the argon supply is stopped. The welding current
is achieved by adjusting the iron core of the reactor L by the forward and reverse rotation of the servo motor Mi.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- In-depth analysis of DC-AC converter inverter
- Basic connection circuit of signal and power supply composed of ISOll3
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Transformerless AC-DC constant current LED driver circuit
- The constant current source composed of two transistors can drive high power
- Principles and precautions of active discharge circuit
- Boost drive circuit composed of RT8450
- CNC regulated power supply production
- MAX1811 Lithium Battery Charger Production
- Rice mill circuit
- Straw returning to field crusher circuit
- Household advance working remote control circuit - transmitter circuit
- Paper mill automatic paper cutter circuit
- Plastic bag sealing machine circuit
- Using CMOS to form a time-adjusted spot welding machine circuit a
- AX1-500 DC arc welding machine circuit
- BX1 series AC arc welding machine circuit
- Thyristor magnetizer circuit 2
- DC motor armature connected in series with resistor to start energy-consuming braking one-way operation circuit 3
