Thyristor magnetizer circuit 2
Source: InternetPublisher:spectrum Keywords: Thyristor electromechanical BSP Updated: 2020/10/05
This semi-automatic magnetizing machine is used to magnetize the large magnetic iron rollers of spinning yarn in textile mills, which can improve
the quality and efficiency of magnetization. Its principle circuit can also be used in other situations.
The delay setting of the time relay KT is set to 10s, that is, it is automatically magnetized every 10s. It can also be set according to specific circumstances.
The excitation coil L is wound with 188 turns of enameled wire with a diameter of 1-88mm on a +50×100mm frame.
- Op amp power supply decoupling bypass measures
- Transformerless AC-DC constant current LED driver circuit
- Switching power supply circuit composition and function introduction of each part
- Principles and precautions of active discharge circuit
- Voltage-current converter constructed with XTR110
- Adjustable regulated power supply with current limiting protection
- CNC regulated power supply production
- USB power socket using the car battery
- Mc34063 MP3 Switching Charger
- Car Audio Power Supply
- Voice controlled flash LED light circuit diagram
- strain sensor
- stuttering correction circuit
- Ultrasonic blind pathfinder circuit
- Rural vegetable greenhouse lighting circuit
- Poultry warming temperature control circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- superheterodyne radio circuit
- Color display circuit
- Small current generator circuit
