BX3 series AC arc welding machine circuit c
Source: InternetPublisher:难得正经 Keywords: Arc welding machine electromechanical winding Updated: 2020/02/15
BX3 series (BK series) AC arc welding machine has a moving coil structure, as shown in Figure 9-5. There are two types of current adjustment: coarse adjustment and fine
adjustment. For coarse adjustment, the windings can be connected in series or in parallel by changing the switch and changing the connecting piece on the output terminal board .
When the primary and secondary windings are connected in series, it is the I connection method, and when they are connected in parallel, it is the II connection method. Fine adjustment is to turn the handle to move the secondary winding up and down along the iron core column
to change the distance between the primary and secondary windings , change the leakage reactance between them, and thereby change the welding current.
- Build a simple buck-boost regulator and test it on a breadboard
- What kind of circuit is a voltage regulator circuit?
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Detailed explanation of 5v charger circuit diagram
- Principles and precautions of active discharge circuit
- USB power socket using the car battery
- Electric bicycle battery charger circuit
- Design of electric vehicle charger
- Adjustable voltage regulated power supply circuit
- LM317T voltage regulation adjustable circuit diagram explanation
- Straw returning to field crusher circuit
- Household advance working remote control circuit - transmitter circuit
- Paper mill automatic paper cutter circuit
- Automatic winding machine circuit
- Structure diagram of drum washing machine motor drive circuit
- One of the foot pedal spot welding machine circuits
- Thyristor controlled contact welding machine circuit
- GZ-600 argon arc welding machine circuit-03
- GZ-600 argon arc welding machine circuit-02
- BX3 series AC arc welding machine circuit b
