Automatic periodic switching circuit 2
Source: InternetPublisher:张三叔 Keywords: Switching circuit BSP relay PI Updated: 2021/04/16
It uses 555 time base integrated circuit A as the time control component} and uses a capacitor step-down circuit;
a bidirectional thyristor V is used to control the power-on and power-off time of the relay
or load.
Adjusting the potentiometers RPi and RP2 (or Cl) can change the pull-in and release time of relay KA respectively. For example, if RPi
is adjusted to 300k,0 and RPz is adjusted to 220kfl, the pull-in time of KA is 20s and the release time is 15s.
- How to choose the right level of integration to meet motor design requirements?
- Servo motor pin diagram/working principle/application
- How to remotely control devices using ESP8266 and LPC2148
- Use your smartphone to turn on/off the power in your home
- Design and principle analysis of practical electric curtain remote control device
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and analysis of a four-bit remote control component capable of remote reset
- An experimental model of an infrared radio alarm
- Precious home appliance anti-theft alarm
- Car audio system anti-theft circuit
- Electronic thermometer circuit
- stuttering correction circuit
- Rural fish farming control circuit
- Diode square rate detection circuit
- Amplitude modulation circuit composed of MC1496
- Wien bridge oscillator circuit
- Inductive feedback oscillator circuit
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Power phase sequence display circuit
