The third delay circuit using 555 time base integrated circuit
Source: InternetPublisher:宋元浩 Keywords: delay circuit integrated circuit time base integration Updated: 2020/09/06
It is a delay circuit that jumps from low level to high level . That is, after pressing the button SB, after
a delay, the output terminal jumps to high level and remains there until the power is turned off.
Adjust the potentiometer R to change the delay time.
The load Rfz can also be changed to a relay or contactor, and then their contacts can control larger loads.
- Tutorial on making your own remote-controlled robotic arm
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- A simple door handle touch alarm circuit
- How to set up a cheap beam break sensor control distance scene using a reflector
- Controlling stepper motors with wireless remote control transceiver and PE-51 board
- One-way rotation circuit of motor controlled by contactor
- Design and production of wireless multi-location control switch circuit
- Motorcycle anti-theft device circuit design
- Delay switch made with LM431
- Water supply reminder after water outage
- Homemade disinfectant circuit
- Electric plow control circuit
- Photoelectric tracking control circuit
- Assembly line outage monitoring circuit
- Delay circuit using 555 time base integrated circuit 5
- Thyristor cut-off delay circuit 3
- One of the conductive tube controlled charging short delay circuits
- Simple power-on delay trigger circuit
- High sensitivity acoustic vibration alarm circuit
- Long delay circuit composed of 555 integrated circuit
