Delay circuit using 555 time base integrated circuit 5
Source: InternetPublisher:aerobotics Keywords: Delay circuit integrated circuit time base integration BSP Updated: 2021/08/26
After pressing the button SB, the power supply of the load Rfz is turned on. After a delay, the power supply
is automatically cut off.
Adjust the potentiometer RP to change the delay time.
- Servo motor pin diagram/working principle/application
- How to Make a Simple 2-Step Arduino Programmable Timer Circuit
- Design of an autonomous plant watering system using ATtiny85
- Introduction to the internal structure of the Delta winding motor
- How to set up a cheap beam break sensor control distance scene using a reflector
- Star-delta step-down starting control circuit for squirrel cage asynchronous motor
- Motor self-starting circuit
- Audio interface protection circuit
- A novel and practical power line anti-theft and cutting alarm circuit
- Water supply reminder after water outage
- Voice controlled flash LED light circuit diagram
- Physiotherapy ventilator circuit
- Particle clogging alarm circuit of wheat seeder
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Simple AGC circuit in transistor radio
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- superheterodyne radio circuit
- Guest arrival signal recognition circuit
- Motorcycle flash light circuit
