A single-section transistor performance test circuit
Source: InternetPublisher:三岁就很酷 Keywords: transistor test circuit transistor single junction transistor Updated: 2020/06/29
This article introduces a single-section transistor performance test circuit diagram . As shown in the figure below, the single-junction transistor VBT under test (assumed: BT33), R3, and C2 form a relaxation oscillator. When VBT is on, the transistor VT1 obtains the bias current through the bias resistor R2 (at this time, S1 is open and S2 is closed), and the light-emitting diode H1 emits light.
Among them, the 10V power supply charges C2 through R3 via VD2. Voltmeter V can measure that the voltage across C2 will continue to rise as time goes by. When the potential at E reaches the peak voltage of VBT, E~B1 of VBT will automatically conduct, and the voltage on capacitor C1 will pass through E~B1 Discharge causes the emitter junction of transistor VT1 to be reverse-biased and cut off, and H1 goes out. If the single-junction transistor VBT under test is good, the capacitor C1 will charge and discharge repeatedly, and H1 will flash alternately between light and dark. If H1 is always on, you can swap the B1 and B2 pins of the VBT for detection (this will also make it easier to correctly distinguish the Bl and B2 pins), otherwise the single-section transistor is a bad tube.
![A single-section transistor performance test circuit](http://www.eeworld.com.cn/circuit/upload/9c1e600a11c00f70696aee55190978e6/aac960dad7508e9509f648acc2ef445e.jpg)
- The basic principles of power supply design. What are the key components of a power supply?
- Benefits of Wide Bandgap Technology for Power Converters
- What kind of circuit is a voltage regulator circuit?
- Use pulse width modulation to get a precise output voltage
- Current/voltage conversion circuit using current converter
- A small and easy-to-make fast charger
- Power supply circuit that can reduce LM317 ripple
- 0.7~24V continuously adjustable current limiting power supply
- Adjustable voltage power socket
- Homemade Electric Bike Fast Charger
- Analysis of transistor and several constant current source circuits
- Current Detection Circuit Design Tips
- Six common constant current source circuit diagrams and analysis
- Circuit diagram of triode inverter
- Acousto-optic digital level detector circuit diagram
- White noise electronic lullaby circuit diagram
- Color changing flash light principle circuit diagram
- Transistor time relay circuit 5a
- Transistor reference basic bias circuit-current negative feedback type
- Gas-sensitive alarm circuit 4
