Capacitance measuring instrument circuit
Source: InternetPublisher:MartinFowler Keywords: Capacitance measuring instrument ammeter Updated: 2020/01/20
![<strong><strong>Capacitance</strong> Measuring instrument</strong><strong>Circuit</strong>](http://www.eeworld.com.cn/circuit/upload/3e4c96f0812bb2c668ee1e6938729e91/d927d724edc4536a3d26e81d3e6fac76.jpg)
This measuring instrument can measure capacitance from several pF to 0.1uF, and the range is divided into five levels: 25pF, 100pF, 1000pF, 0.01uF and 0.1uF. Since the measurement principle is linear, it can be read directly using the ammeter scale.
When VT4 is turned on, the measured capacitor Cx and diode VD discharge. When VT4 switches once, the measured capacitor is charged and discharged once. The capacitance being measured is large, and more electricity passes through the ammeter each time it is charged; in addition, VT4 switches more times per second, and more electricity passes through the ammeter per second. The amount of electricity passing through the ammeter per second is the current flowing through the ammeter. Therefore, the current through the ammeter is proportional to the capacitance being measured, and proportional to the switching frequency of VT4. If the current passing through the ammeter is required to be the same, then the switching frequency of VT4 must be higher when measuring small capacitors .
- The basic principles of power supply design. What are the key components of a power supply?
- How much current can a 2N3055 solar cell produce? How can I get 3055V from a 12N2 solar cell?
- Driving circuit of switching power supply field effect tube
- What kind of circuit is a voltage regulator circuit?
- Visible laser digital control modulation driver
- The constant current source composed of two transistors can drive high power
- Miniature polarity reversal power supply using MAX1721
- 0.7~24V continuously adjustable current limiting power supply
- Constant current charger using light emitting diode as voltage regulator
- MIC4680 constant current charger
- Design of adjustable DC stabilized power supply circuit module
- 500A-6V single-phase thyristor voltage regulating electroplating power supply circuit
- The ammeter is connected to the circuit through the current transformer phase switch and switches c
- The ammeter is connected to circuit b through the current transformer
- audio power circuit
- Additional power circuit design for USB devices
- Household emergency power circuit 02
- Remote control TV doorbell power circuit
- Power circuit for home appliance repair
- DC ammeter wiring method
