Battery fast charging circuit 2
Source: InternetPublisher:刘德华河北分华 Keywords: Fast charging battery charging circuit rectifier circuit Updated: 2020/01/05
It is mainly composed of main charging circuit, trigger circuit, constant current circuit and automatic charging and discharging circuit
. Adjust the potentiometer RPi to change the charging current.
Since this circuit is directly connected to the mains, you must pay attention to safety when using it. The circuit uses a semi-controlled rectifier circuit , so
the power supply efficiency of the motor is not high. If the power supply is stepped down through a power transformer and a fully controlled rectifier circuit is used , the efficiency can be improved and the power supply is
safer.
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- Cleverly use the electronic ballast of waste energy-saving lamps as power supply transformer
- Introduction and principle analysis of switching regulated power supply
- Recommended circuits for different power on times of LM4911
- Op amp power supply decoupling bypass measures
- BA6104 five-digit LED level meter driver integrated circuit basic application circuit
- Current/voltage conversion circuit using current converter
- Voltage-current converter constructed with XTR110
- Practical constant current charger-----Constant current charger
- How to Select Modular EMI Filters for AC-DC Converters
- Battery constant current charging circuit
- Battery fast charging circuit 2
- Multifunctional charging circuit diagram
- With leakage charging circuit
- Motorcycle battery clever charging circuit
- Wind turbine battery charging circuit
- Multifunctional automatic charging circuit
- Control input start charging circuit diagram b
- Control input start charging circuit diagram a
- Pulsating constant current charging circuit diagram
