Multifunctional charging circuit diagram
Source: InternetPublisher:张小哥 Keywords: Circuit diagram charging circuit output voltage LED Updated: 2020/11/21
This charger can charge 3.6V 1300mAh lithium battery, AA and AA Ni-MH batteries. In addition, this circuit can also be used as a regulated power supply for 1.5V or 3V radios and receivers. The charger can automatically switch from fast charging, slow charging, constant voltage charging, and finally trickle charging. The circuit eliminates the control components necessary for high-current charging, reduces costs, and simplifies the circuit, making it easy to make and debug. The circuit is shown in the figure above, and the figure below is the printed circuit board diagram.
Working principle: This charger circuit is essentially a low-voltage regulated power supply. The upper half of the circuit charges lithium batteries, and the lower half charges 1.2V nickel-metal hydride batteries. The charging principles of the two are the same. Transistor VT1 is an adjustment tube. VT2 and VT3 form an error amplifier. LED 1 (two diodes are used in the lower half of the circuit) serves as the reference voltage and power indicator. When the charger output voltage is 4V and the lithium battery is at 2.8V, due to the current limit of R5 and the maximum charging current of 300mA, the voltage drop at both ends of VTlec is only 0.15V, and no radiator is needed. The charging current decreases as the battery voltage increases, and finally enters a trickle charging state. When charging imported lithium batteries, foreign circuits charge lithium batteries to about 3.8V, so the output voltage is adjusted to 4V; if it is a domestic lithium-ion battery, it should be adjusted to 4.2V. This charger is not afraid of short circuit. When the output terminal is short-circuited, the maximum current is 500mA and the VTlec voltage drop is 0.1V, so it is still safe for VT1. The lower half of the
simple and easy-to-make multifunctional charging circuit Battery charging circuit
charges 1 to 3 cells of AA and AA nickel-metal hydride batteries. The maximum charging current is about 220mA. Set the switch Sw to 1, 2, and 3 to charge 1-3 batteries respectively, and the corresponding output voltage should be adjusted to 1.3V, 2.6V, and 3.9V. LED2 lights up during charging, and the brightness of LED2 gradually dims as the battery voltage rises. When LED2 goes out, the battery enters trickle charging.
Use this circuit as the power supply of the radio and amplifier, and adjust the output voltage of the upper half circuit to the required voltage of 1.5V or 3V. If it cannot be adjusted to 1.5V, replace LED 1 or use 2 diodes. Circuit performance: When the output voltage is 1.5V and 300mA, the voltage drops by about 0.1V; when the output voltage is 3V and 300mA, the voltage drops by about 0.2V.
- Use pulse width modulation to get a precise output voltage
- Low cost and high performance LED constant current power supply
- Power supply circuit that can reduce LM317 ripple
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- Electric bicycle battery charger circuit
- MIC4680 constant current charger
- MAX1811 Lithium Battery Charger Production
- A low-cost, high-reliability battery charger for electric vehicles
- Homemade Electric Bike Fast Charger
- What sensors does the phone have?
- Ambulance electronic flash signal circuit diagram
- Driving circuit diagram of a low-power LED bulb
- Circuit diagram for using an ordinary TV remote control to control switches of other home appliances such as light bulbs and fans
- Simple light-emitting display logic pen circuit
- S8050 low-cost high-performance LED constant current power supply circuit diagram
- 3W high power LED drive circuit diagram
- 5-point LED driver circuit diagram of HA7666P/TA7667P
- Electric blanket internal disconnection measurement circuit
- Light emitting diode (LED) display driver circuit
