Multi-speed constant current charger circuit
Source: InternetPublisher:李商隐身 Keywords: charger constant current electromechanical Updated: 2021/01/05
The circuit structure is simple and has good performance. It can charge 1 to 10 12V
batteries of the same specifications simultaneously after being connected in series. The charging current passes through the switches S]~S. You can choose between 1-15A. Once the current
is selected, it can be kept constant and will not be affected by grid voltage fluctuations and load changes, eliminating
the trouble of adjusting the electric sulfur during the charging process; the output end is not afraid of short circuit, even if Even if the output terminal is short-circuited and run for a long time, the rectifier diode and other components will not be damaged
, so the reliability is very high; the power consumption is low, the heat generated by the whole machine is small, and the internal temperature is low during operation.
The inductor L can be made of a double wire of 1.5mm enameled wire and wound with 32 turns to make an air-core coil with a diameter of 120mm.
- How to Make a Soft Latch Circuit
- Schematic diagram of car cigarette lighter to USB power port
- Step-down power supply for driving relays
- Brief Analysis of the Working Principle of AC Voltage Stabilizer Circuit
- Detailed explanation of 5v charger circuit diagram
- How to use SBR to improve power conversion efficiency
- Adjustable regulated power supply with current limiting protection
- Integrated regulated power supply with continuously adjustable output voltage
- 0.7~24V continuously adjustable current limiting power supply
- Electric bicycle battery charger circuit
- GCA-60 (0-36, 0-72) silicon rectifier charger circuit
- GCA-30 (0-36, 0-72) silicon rectifier charger circuit
- Thyristor automatic charger circuit
- Small thyristor charger circuit 5
- One of the small thyristor charger circuits
- Typical application circuit of XLT604 in AC and DC input
- Constant current LED drive circuit based on switching power supply
- 5A constant voltage/constant current regulated power supply
- Constant current charging circuit diagram composed of LT1307
