Load limiter circuit 2 using 555 time base integrated circuit
Source: InternetPublisher:闪电杰克 Keywords: Integrated circuit time base integration electrical circuit BSP Updated: 2020/04/27
The second load limiter circuit using 555 time base integrated circuit
is as shown in the figure. It can control 1-10A load; when the load exceeds the set value for more than 7 seconds,
the power supply will be cut off, the power supply will be stopped, and the power supply will be restored after 5 minutes, and the load will be monitored again.
It uses capacitors to step down the voltage and uses 555 time base integrated circuit A to form a monostable delay circuit. Adjust the potentiometer RPi
to change the allowed startup overload time. In the figure, KP is a reed switch. If the load current is limited to 1A,
the number of pull-in turns wound on the glass tube is about 15; if the limited current is 10A, the number of pull-in turns wound around it is about 2 turns.
- Design and analysis of a simple zero-crossing power regulator circuit
- Share a home telephone recorder circuit diagram
- DC detection automatic watering controller circuit
- Senlan BT40 multi-unit proportional linkage
- Panasonic NR-172TA-X refrigerator circuit
- Simple stepless speed fan circuit
- Charger circuit
- HA1167 is used as the third image intermediate amplifier circuit for black and white TV sets
- Transformer AC contactor DC operation circuit a
- Water and electricity saving faucet circuit 2
- Set timing circuit when power is on
- Excellent performance household inverter power supply circuit
- Self-defense anti-riot circuit
- Ultrasonic blind pathfinder circuit
- Physiotherapy ventilator circuit
- Soil water shortage prompt circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- Diode Balanced Mixer Circuit
- superheterodyne radio circuit
- Home appliance repair signal generator circuit
