Add an anti-interference capacitor to the output of the amplifier
Source: InternetPublisher:清宁时光 Keywords: Amplifier BSP frequency converter Updated: 2020/10/11
(2) Frequency converter anti-interference wiring 2
The wiring is as shown in the figure. The photoelectric relay and the frequency converter are in the same system and share the power supply. When the frequency converter is running
, the high-order harmonics generated by the frequency converter will cause the relay to malfunction. To do this,
install a 0. OltLF capacitor C between the COM terminal of the amplifier output and the chassis . to eliminate malfunctions.
- Fabrication of multi-cell lithium battery charging circuit
- Use pulse width modulation to get a precise output voltage
- Detailed explanation of 5v charger circuit diagram
- Dual forward converter schematic diagram
- Dynamic power supply for power amplifier controlled by thyristor
- UC3842 Electric Vehicle Charger
- Car Audio Power Supply
- LM317T voltage regulation adjustable circuit diagram explanation
- Battery powered switching circuit diagram
- How to Select Modular EMI Filters for AC-DC Converters
- electromagnetic field sensor
- Voice controlled flash LED light circuit diagram
- Electronic thermometer circuit
- Pulse therapy circuit
- Physiotherapy ventilator circuit
- Chicken supplementary light to increase egg production rate circuit
- Biogas concentration detection line
- Voltage series negative feedback amplifier circuit
- Second-order active band-stop filter circuit
- Color display circuit
