Easy-to-make integrated circuit signal tracker circuit
Source: InternetPublisher:难得正经 Keywords: Signal Tracker Updated: 2024/10/08
The integrated circuit signal tracker circuit is simple, and only needs a low-power integrated amplifier circuit LM386 and 5 capacitors to form the whole machine, and the tracking ability is extremely strong. From the tuning circuit to the power amplifier circuit, the fault can be easily detected. Because of the loud sound, when checking the middle and low-power circuits, you can also use the speaker to play the sound, without having to wear headphones all the time, which is very convenient to use.
The circuit principle is shown in the figure above. Cl is a DC blocking capacitor; C2 is an output capacitor; C3 is used to prevent self-excitation; C4 is a power supply filter capacitor.
The signal is input from the 3rd pin of the integrated circuit LM386 through Cl. Since the input end of LM386 is biased by micro-current and has a wide frequency response, detection can be completed without an external diode. The signal is amplified and output from the 5th pin of LM386. The 1st and 8th pins of LM386 are gain controls. The highest gain can be obtained by directly connecting the two pins with a 10μF capacitor.
The printed circuit board of the machine is shown in the figure below. All components are installed on a 2cm×3.5cm printed circuit board. As long as the components are selected correctly and the wiring is correct, it can generally work normally without debugging. The headphone socket needs to be modified to make it also serve as a power switch. Since this signal tracker consumes very little power, the static current is only about 4mA, it can be powered by 4 No. 5 batteries. If 6V laminated batteries are used, the size can be further reduced.
- Detailed explanation of the working principle of the clapper activated optical circuit
- DIY an electromagnetic glove
- IoT-based weather data logger
- Build a Raspberry Pi-based QR code scanner
- DIY an indoor and outdoor webcam
- The production of ultra-low-cost anti-theft system based on Blues wireless note card
- Low voltage electronic self-defense baton
- A novel resonance demonstration device
- How to Design a Wireless Remote Controlled Two-Wheeled Robotic Rover Using ESP8266 and Arduino Uno
- Test and Application of Power Amplifier TDA7294
- How does an optocoupler work? Introduction to the working principle and function of optocoupler
- 8050 transistor pin diagram and functions
- What is the circuit diagram of a TV power supply and how to repair it?
- Analyze common refrigerator control circuit diagrams and easily understand the working principle of refrigerators
- Hemisphere induction cooker circuit diagram, what you want is here
- Circuit design of mobile phone anti-theft alarm system using C8051F330 - alarm circuit diagram | alarm circuit diagram
- Humidity controller circuit design using NAND gate CD4011-humidity sensitive circuit
- Electronic sound-imitating mouse repellent circuit design - consumer electronics circuit diagram
- Three-digit display capacitance test meter circuit module design - photoelectric display circuit
- Advertising lantern production circuit design - signal processing electronic circuit diagram
