A high-precision digital long delay circuit
Source: InternetPublisher:睡不醒的小壮 Keywords: Delay circuit MCI4521B Updated: 2024/08/08
The general long delay circuit usually relies on electrolytic capacitors or high impedance circuits. This type of delay circuit has poor stability and low delay accuracy. Here is a digital long delay circuit that completely abandons large electrolytic capacitors and high impedance circuits and has high delay accuracy.
1. Circuit Working Principle
The circuit principle is shown in the figure below.
The core of the circuit is the integrated block MCI4521B, which is a 24-level frequency division circuit, including an inverter that can form an oscillation circuit. If the trigger input is grounded or no signal is added, the circuit enters the delay state, and the delay time is adjusted by the range switch X and the 100KΩ potentiometer.
If X is connected to point A, the delay is 1 minute 40 seconds to 18 minutes 30 seconds, and if X is connected to point B, the delay is 13 minutes 20 seconds to 2 hours 28 minutes. When X is connected to point C, the delay is 1 hour 47 minutes to 20 hours. The specific delay time is adjusted by the 100KΩ potentiometer. If a longer delay is required, a large capacitor can be used instead of the 39nF capacitor. In this case, the delay can reach more than one week.
When a positive signal is added to the trigger output, the divider in 4521B is reset.
2. Component Selection and Production
IC uses MCI4521B integrated circuit; Rl~R4 use 1/4W metal film resistors; RP uses organic solid variable resistors. C1 uses ceramic chip capacitors. VD1 uses IN4004 silicon rectifier diodes; VD2 uses IN4148 silicon switch diodes. VT uses BC337 silicon triodes; VS uses 1W, 15V silicon voltage regulator diodes. Connect the circuit as required, and it can work normally without debugging. The delay is reliable and stable, and it is recommended to be powered by a 6~15V voltage regulator.
- The meaning and importance of circuit protection, common types of circuit protection
- Build a Smart Garage Door Opener Using a Raspberry Pi
- How to Make a Hot Tub Smart and Remotely Operated with a Raspberry Pi
- Perform surgery on the speaker protection circuit
- A small improvement to the temperature and water level indicator alarm
- Motor automatic cycle control circuit
- JDB-LQ-TQ/2 motor full voltage starting circuit
- Squirrel cage asynchronous motor reverse braking control circuit
- IGBT modules block overcurrent by controlling the gate
- Design and production of wireless multi-location control switch circuit
- Differential amplifier emitter negative feedback gain control circuit
- Remote control receiving circuit of Panasonic inverter air conditioner indoor unit control circuit
- Micro remote control receiving and control circuit
- Photocell amplification control circuit
- Digital camera flash control circuit
- Delay circuit using 555 time base integrated circuit 4b
- Delay circuit using 555 time base integrated circuit part 4a
- Thyristor cut-off delay circuit part 5
- One of the lighting delay circuits using transistors
- Improved delay circuit with diode added to electromechanical control
