Delay circuit using 555 time base integrated circuit 4b
Source: InternetPublisher:newlandmark Keywords: delay circuit integrated circuit time base integration Updated: 2021/04/27
They are a delay circuit that jumps from high level to low level . That is, when the button SB
is pressed, the output terminal is high level. After a delay, the output terminal jumps to low level and remains low level .
Adjust the potentiometer RP to change the delay time.
The circuit uses a unidirectional thyristor
to supply only half-wave power to the load.
- How to build a simple tachometer using an infrared reflectance sensor
- A small improvement on the ordinary refrigerator motor starting circuit
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Working principle of one Xipu STR soft starter controlling two motors
- Design and production of radio remote control fan stepless speed regulator
- Light-controlled circuit design and analysis
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Design and manufacture of three-phase motor protection circuit
- Motorcycle anti-theft device circuit design
- Password type motorcycle anti-theft device
- Homemade disinfectant circuit
- Electric plow control circuit
- Photoelectric tracking control circuit
- Assembly line outage monitoring circuit
- Delay circuit using 555 time base integrated circuit 5
- Thyristor cut-off delay circuit 3
- One of the conductive tube controlled charging short delay circuits
- Simple power-on delay trigger circuit
- High sensitivity acoustic vibration alarm circuit
- Long delay circuit composed of 555 integrated circuit
