Flashing light circuit design and analysis
Source: InternetPublisher:ohahaha Keywords: Flashing light circuit Updated: 2024/09/25
The working principle of the device application circuit is shown in Figure 10. When used as a flashing light control, as long as an intermittent voltage is added to the ④ end of the controller DM, the load H of DM will flash continuously. In this example, a music integrated circuit IC is used to connect the signal output end O/P of the music IC to the ④ end of the controller DM, and the positive and negative ends of the power supply of the music IC are connected to the ① and ⑤ ends of DM. If the music IC is replaced with a special flash chip, it can also form a navigation light, a municipal road construction light, a special signal light, etc. If a dance party is held at home, the ④ and ⑤ ends of the controller DM can also be connected to a plug and inserted into the output jack of a sound source such as a tape recorder. At this time, the lighting lamp H will flash with the rhythm of the music. A 10A controller DM can drive thousands of watts of colored lights to work.
- How to use a microcontroller to control a servo motor?
- Analysis of the working principle of car garage door lights
- How to Make a Simple Chicken Incubator
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Add one more component to improve the phase failure protection function
- IGBT modules block overcurrent by controlling the gate
- Audio interface protection circuit
- Ultra-short wave item left behind reminder alarm
- Precious home appliance anti-theft alarm
- Electric plow control circuit
- Multi-channel patrol detection control circuit b
- Photocell trigger control circuit
- Water dispenser double sheet control circuit
- Table printing machine control circuit
- Haier KFR-25GW air conditioner control circuit schematic diagram
- Bedside touch light detection control circuit
- Timing and fire power control circuit
- Temperature detection control circuit of electric kettle
- Typical electronic volume control circuit
