Output voltage expansion circuit d
Source: InternetPublisher:ohahaha Keywords: Output voltage BSP operational amplifier Updated: 2021/11/29
The allowable output voltage and maximum output power of the operational amplifier are limited, and are specified in the technical specifications of the operational amplifier
. For example, the maximum output voltage of F007 is ±12V, and the static power consumption is ≤150mW. In some cases it is not large enough,
so an expansion circuit must be used. The
common output voltage expansion circuit is shown in the figure
- How do pull-up resistors work? How do I choose a pull-up resistor value?
- What is the function of a voltage regulator in a circuit? How to connect a voltage regulator?
- Classification and characteristics of operational amplifiers, classification and characteristics of operational amplifiers
- What is the difference between CPLD and FPGA?
- How to Build a Simple Temperature Indicator Circuit Using NTC and PTC Thermistors
- Share a Motorola amplifier circuit
- What is a Demultiplexer
- What is the difference between high-side and low-side resistive current sensing
- Make a simple AM radio with digital circuit
- Experiment and production of NE555 time base integrated circuit
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Straw returning to field crusher circuit
- Greenhouse temperature control circuit
- Egg heating control circuit
- Double gate field effect transistor high frequency amplifier circuit
- Guest arrival signal recognition circuit
- Home appliance repair signal generator circuit
