AAT circuit for sectional bus backup power b
Source: InternetPublisher:方世玉223 Keywords: Backup power supply BSP circuit breaker Updated: 2021/11/25
For wiring with two independent power supplies and single busbar segments as mutual backups, the backup power automatic input device (AAT)
should be installed on the segmented busbar circuit breaker , and its circuit is shown in Figure 14-145. This circuit uses a DC operating power supply, and the starting method
adopts a time-limited low-voltage start.
In the figure, the control switch SAi is used to operate the circuit breaker . The selector switch SAz is used to switch the AAT device, and
the contacts in the dotted box represent those from the control loop.
When the load current is low, adjust the potentiometer RP to make the relay KA reliably close.
- A very convenient small power supply circuit to share
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Basic circuit description of adjustable voltage regulator LM317
- Detailed explanation of 5v charger circuit diagram
- An ultra-low output voltage regulator
- CNC regulated power supply production
- 0.7~24V continuously adjustable current limiting power supply
- MIC4680 constant current charger
- Adjustable voltage regulated power supply circuit
- Motor forward and reverse control wiring diagram (2)
- High-efficiency speaker circuit for rural stage
- Chicken supplementary light to increase egg production rate circuit
- Agricultural small tractor lighting circuit
- Amplitude modulation circuit composed of MC1496
- ring amplitude modulation circuit
- Wien bridge oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage-controlled voltage source second-order band-pass filter circuit
- Guest arrival signal recognition circuit
