Contactor mutual switching circuit for dual power supply part 2
Source: InternetPublisher:吃掉星星 Keywords: Power supply BSP contacts Updated: 2021/02/25
Mutual switching of dual power supplies means that the load is powered by two power supplies, and the two power supplies work at the same time and bear the electrical load respectively. When
one of the power supplies fails, the tie switch automatically closes, and all loads are powered by the non-power outage circuit.
The circuit is shown in the figure. Under normal circumstances, power supply No. 1 supplies power to the load of section A bus, and power supply No. 2 supplies power to
the load of section B bus. Note: The auxiliary contacts
of circuit breakers QFi and QF2 must act one At time before the main contacts (mechanical
adjustment is available), otherwise two different power supplies will merge in an instant, causing a short circuit.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- A very convenient small power supply circuit to share
- Practical and convenient fax machine power supply control circuit
- Basic connection circuit of signal and power supply composed of ISOll3
- Single-power supply circuit for ISO122P/ISO124
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- Integrated regulated power supply with continuously adjustable output voltage
- Electric bicycle battery charger circuit
- Motor forward and reverse control wiring diagram (2)
- strain sensor
- Ultrasonic blind pathfinder circuit
- Bone hyperplasia treatment circuit
- Egg heating control circuit
- DC ammeter
- Series crystal oscillator
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Small current generator circuit
