One of the contactor mutual switching circuits for dual power supplies
Source: InternetPublisher:子丑寅卯 Keywords: Power supply BSP contacts Updated: 2021/10/24
Mutual switching of dual power supplies means that the load is powered by two power supplies, and the two power supplies work at the same time and bear the electrical load respectively. When
one of the power supplies fails, the tie switch automatically closes, and all loads are powered by the non-power outage circuit.
The circuit is shown in Figure 14-131. Under normal circumstances, power supply No. 1 supplies power to the load of section A bus, and power supply No. 2 supplies power to
the load of section B bus. Note: The auxiliary contacts
of circuit breakers QFi and QF2 must act one At time before the main contacts (mechanical
adjustment is available), otherwise two different power supplies will merge in an instant, causing a short circuit.
- 5 Converter Topologies for Integrated Solar and Storage Systems
- Schematic diagram of car cigarette lighter to USB power port
- Practical and convenient fax machine power supply control circuit
- What kind of circuit is a voltage regulator circuit?
- Transformerless AC-DC constant current LED driver circuit
- A small and easy-to-make fast charger
- Integrated regulated power supply with continuously adjustable output voltage
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- Practical constant current charger-----Constant current charger
- Motor overcurrent protection circuit
- Chicken supplementary light to increase egg production rate circuit
- Farmland irrigation automatic control circuit b
- DC ammeter
- Junction field effect transistor mixer circuit
- Motorcycle flash light circuit
- Digital stopwatch display circuit
- Various signal generator circuits
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (1)
