Contactor automatic switching circuit for dual power supply part 2
Source: InternetPublisher:拳制龙 Keywords: Power supply BSP Updated: 2021/03/17
The two power supplies can serve as backup for each other.
Component selection: D210-100/3 is selected for low-voltage circuit breakers QFi and QFz (determined by load capacity). The combined switches
SAi and SA2 are of type H210-10/2. The fuse is selected as RLl-15/5A. Contactors KMi and KM2 use CJlo-
100/380V (determined by load capacity). The indicator light uses XD3-220/15V, 2V. A or other models. The selection of
the above components can also be used as a reference for each circuit introduced below .
- Build a simple buck-boost regulator and test it on a breadboard
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- Op amp power supply decoupling bypass measures
- Offline 8w LED Flyback Power Supply with PFC using NCP1014
- LED rechargeable flashlight circuit diagram
- Current/voltage conversion circuit using current converter
- USB power socket using the car battery
- Design of electric vehicle charger
- UC3842 Electric Vehicle Charger
- A low-cost, high-reliability battery charger for electric vehicles
- strain sensor
- Peanut and melon seeds roasting machine circuit
- Fish farming thermostatic control circuit
- Rural fish farming control circuit
- Farmland drainage automatic control circuit
- collector amplitude modulation circuit
- ring amplitude modulation circuit
- Parallel crystal oscillator
- Crabo oscillator circuit
- Three primary color display circuit
