One of the contactor self-turning circuits for dual power supply
Source: InternetPublisher:containsmachine Keywords: Power supply BSP Updated: 2020/03/13
The two power supplies can serve as backup for each other.
Component selection: D210-100/3 is selected for low-voltage circuit breakers QFi and QFz (determined by load capacity). The combined switches
SAi and SA2 are of type H210-10/2. The fuse is selected as RLl-15/5A. Contactors KMi and KM2 use CJlo-
100/380V (determined by load capacity). The indicator light uses XD3-220/15V, 2V. A or other models. The selection of
the above components can also be used as a reference for each circuit introduced below .
- A very convenient small power supply circuit to share
- How to Make a Soft Latch Circuit
- Energy-saving motorcycle rectifier regulator
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- Voltage-current converter constructed with XTR110
- A simple positive and negative power supply circuit
- MIC4680 constant current charger
- Excellent performance household inverter power supply circuit
- Analysis of rectifier circuit types and principles
- Homemade disinfectant circuit
- Peanut and melon seeds roasting machine circuit
- Greenhouse temperature control circuit
- Electrical schematic diagram of DC voltmeter input at non-inverting terminal
- AC voltmeter
- Crabo oscillator circuit
- Capacitive feedback oscillator circuit
- Voltage series negative feedback amplifier circuit
