Relay protection operation power automatic switching circuit
Source: InternetPublisher:奥特man123 Keywords: Power supply relay protection automatic switching switching circuit Updated: 2020/11/03
When there are two independent power supplies in the substation, the relay protection operation power supply as shown in the figure can be used to automatically
switch lines to replace the battery pack.
In the figure, TV is a voltage transformer for relay protection ; KA is an AC voltage relay, DY-28 type/loOv, set
to 80V release; fuses FUi and FUz are used to prevent the contactor contacts from sticking for short-circuit protection designed.
- In-depth analysis of DC-AC converter inverter
- 220V Remote Load Monitor
- Energy-saving motorcycle rectifier regulator
- ISO113 circuit that can reduce power consumption
- Isolated two-wire current loop circuit (XTR101, ISO100)
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- A novel and practical DC low voltage stabilized power supply
- 3~15V 10A adjustable voltage regulated power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- Minimize noise and ripple using low-noise buck converters
- How to improve the performance of car power supplies
- Analysis of the advantages and disadvantages of electrolytic capacitor-free LED power supply
- Principle and circuit diagram of battery internal resistance tester
- How many power supply methods are there for Arduino? What is the power circuit like?
- Do you know about 180W and 220W high-efficiency adapter power supplies?
- XP Power launches high-efficiency adapter power supply
- Automatically set timer
- AC power supply non-stop switching circuit using transistorsb
- Complementary AC Power Switching Circuit
