Analysis of the advantages and disadvantages of electrolytic capacitor-free LED power supply
Source: InternetPublisher:通通 Keywords: power supply Updated: 2020/06/22
We all know that electrolytic capacitor is a type of capacitor. The metal foil is the positive electrode (aluminum or tantalum). The oxide film (aluminum oxide or tantalum pentoxide) close to the positive electrode is the dielectric. The cathode is made of conductive material and electrolyte (electrolyte can It is composed of liquid or solid) and other materials. Because the electrolyte is the main part of the cathode, the electrolytic capacitor gets its name. At the same time, the positive and negative electrolytic capacitors cannot be connected incorrectly. Aluminum electrolytic capacitors can be divided into four categories: lead type aluminum electrolytic capacitors; horn type aluminum electrolytic capacitors; bolt type aluminum electrolytic capacitors; solid aluminum electrolytic capacitors.
In the minds of ordinary people, the life of LED itself is already very high, but the actual life is very low, which is often caused by the low life of the power supply. The life of the power supply often depends on the life of the electrolytic capacitor. Because it is generally believed that the life of electrolytic capacitors is very low. If the constant current source has no electrolytic capacitor at all, then its lifespan must be very long. What's more, the power factor can be improved after removing the electrolytic capacitor. Therefore, various types of constant current sources without electrolytic capacitors attract a lot of people's attention.
- Build a simple buck-boost regulator and test it on a breadboard
- Driving circuit of switching power supply field effect tube
- Lithium battery overcharge, over discharge, short circuit protection circuit design
- The constant current source composed of two transistors can drive high power
- LNK304 non-isolated LED light string driver circuit
- Low cost and high performance LED constant current power supply
- Voltage-current converter constructed with XTR110
- An ultra-low output voltage regulator
- USB power socket using the car battery
- Adjustable voltage regulated power supply circuit
- Summary of key points of switching power supply PCB layout, worth collecting!
- How to ensure that the power supply works efficiently for a long time?
- How to judge the quality of LED power supply?
- Which power supplies should be chosen for collection?
- Power phase failure display circuit
- Miniature polarity reversing power supply composed of MAX1721
- Medical infusion alarm circuit
- Power outage alarm circuit
- AD597 functional diagram
- Power circuit b composed of intelligent thyristor modules
