Power supply circuit with phase sequence protection
Source: InternetPublisher:明天见 Keywords: power supply circuit power outage motor relay Updated: 2020/03/17
If the phase sequence of the power supply is wrong, serious incidents such as motor reversal, mechanical equipment damage, and production process disruption will occur .
In order to avoid such faults, a phase sequence protection power supply circuit with phase sequence identification function can be used
, as shown in Figure 14-120. When the power supply has a positive phase sequence, the relay KA is closed and the contactor KM is closed, turning on the power supply;
when the power supply is in a negative phase sequence, KA and KM are released and the power supply is cut off.
- Benefits of Wide Bandgap Technology for Power Converters
- Fabrication of multi-cell lithium battery charging circuit
- Recommended circuits for different power on times of LM4911
- Basic connection circuit of signal and power supply composed of ISOll3
- Driving circuit that controls LED brightness using PWM signal
- Detailed explanation of 5v charger circuit diagram
- LNK304 non-isolated LED light string driver circuit
- 0.7~24V continuously adjustable current limiting power supply
- Converting a lithium battery charging board into a constant voltage and current charger
- How to Select Modular EMI Filters for AC-DC Converters
- LCD backlight power supply circuit using voltage divider method
- Power supply circuit for computer motherboard using RT9173-A chip
- Power supply circuit of notebook computer using RT9181 chip
- Camera power supply circuit
- DDR memory power supply circuit
- Automatic periodic switching circuit 4
- Thyristor type overcurrent protection circuit 6
- Multipurpose power outage alarm circuit
- 5V power supply circuit with temporary backup stable power supply
- AC welding machine no-load breaker circuit
