Transistor-driven AC regulated power supply circuit
Source: InternetPublisher:风向双子座 Keywords: AC regulated power supply transistor regulated power supply circuit BSP Updated: 2020/04/04
Using a relay to change the tap of an autotransformer to regulate voltage has the advantages of simplicity, economy, and a wide range of voltage regulation.
The disadvantage is that the voltage stabilization performance is poor and the voltage is regulated in stages. Improper adjustment can easily cause loss of control.
The circuit is shown in the figure. When the power supply voltage of this circuit changes from 170 to 250V, the output voltage is maintained within
220V ± 10V, and the voltage regulator capacity is 150V. A.
The working status of each component in the circuit is shown in the table
- How to use a simple circuit to achieve a smooth soft-start for an isolated converter
- 220V Remote Load Monitor
- Driving circuit of switching power supply field effect tube
- INA155/INA156 is used to form a single-supply high-side current monitor for detecting load current
- Driving circuit that controls LED brightness using PWM signal
- Principles and precautions of active discharge circuit
- Using CW34603 to form a circuit to change the polarity of the output power supply
- Dual forward converter schematic diagram
- An ultra-low output voltage regulator
- Production of backup power supply for cordless phone
- Voice controlled flash LED light circuit diagram
- stuttering correction circuit
- Pulse therapy circuit
- Inpatient pager circuit
- Soil water shortage prompt circuit
- Junction field effect transistor mixer circuit
- Diode balanced amplitude modulation circuit
- common emitter amplifier circuit
- Wireless microphone circuit
- Small current generator circuit
