Auto-coupling voltage regulator AC stabilized power supply circuit
Source: InternetPublisher:太白金星 Keywords: AC regulated power supply voltage regulator regulated power supply circuit BSP Updated: 2021/07/29
The servo motor controlled auto-voltage regulator AC voltage stabilizer has the advantages of simple structure, high sensitivity, undistorted output waveform, and
wide voltage regulation range.
The circuit is shown in Figure 14-86. This circuit can make the output voltage basically stable when the input voltage changes in the range of 240~250V
; the minimum adjustment voltage is 2V.
The polarization relay can reflect the polarity of the current, has high sensitivity and rapid action, and can be used in J Hl or 2,
3, 4, and 5 types.
In addition, in order to ensure that the voltage regulator sliding arm can automatically stop when it moves to the limit position of voltage boost or voltage reduction, limit
switches SQi and SQ2 are provided. H] and H2 are the upper and lower offside indicators respectively. Adjusting RPi and RPz can change the output
voltage setting value.
- A very convenient small power supply circuit to share
- Driving circuit of switching power supply field effect tube
- Introduction and principle analysis of switching regulated power supply
- Step-down power supply for driving relays
- Driving circuit that controls LED brightness using PWM signal
- Constant current LED lamp driver circuit with soft start and anti-shock
- How to use SBR to improve power conversion efficiency
- Adjustable voltage power socket
- UC3842 Electric Vehicle Charger
- A low-cost, high-reliability battery charger for electric vehicles
- Motor overcurrent protection circuit
- stuttering correction circuit
- Frequency modulator composed of NE566
- Amplitude modulation circuit composed of MC1496
- Broadband high frequency power amplifier circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Second-order active band-stop filter circuit
- Wireless microphone circuit
- Motorcycle flash light circuit
