AC stabilized power supply circuit suitable for upper limit voltage stabilization
Source: InternetPublisher:通通 Keywords: AC regulated power supply regulated power supply circuit voltage stabilization BSP Updated: 2021/02/26
This circuit only stabilizes the voltage at the upper limit, that is, when the grid voltage exceeds the specified value (such as 220V),
the voltage is stabilized, but when it is lower than the specified value, the voltage cannot be stabilized .
The voltage adjustment is completed by the thyristor V; the equivalent single-junction transistor is composed of triodes VT3 and VT4;
the trigger circuit is composed of capacitors C, VT3, VTt and resistors R8, R9; the voltage dividing circuit composed of R8 and Rg makes VT3 The base potential
rises in proportion to the input voltage.
- A very convenient small power supply circuit to share
- 220V Remote Load Monitor
- Using Lead-acid Battery as Power Source for Walkman
- Use pulse width modulation to get a precise output voltage
- Miniature polarity reversal power supply using MAX1721
- A novel and practical DC low voltage stabilized power supply
- Constant current charger using light emitting diode as voltage regulator
- Converting a lithium battery charging board into a constant voltage and current charger
- MIC4680 constant current charger
- LM317T voltage regulation adjustable circuit diagram explanation
- Voice controlled flash LED light circuit diagram
- Farmland irrigation automatic control circuit b
- DC ammeter
- Wien bridge oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Power phase sequence display circuit
- Small current generator circuit
- Home appliance repair signal generator circuit
