Simple AC voltage-stabilized power supply circuit using series-cut resistor method
Source: InternetPublisher:toothache Keywords: AC regulated power supply regulated power supply circuit BSP Updated: 2021/05/17
This circuit is suitable for voltage
stabilization (actually voltage limiting) in areas with high voltage. When the grid voltage rises, a resistor of a certain value is connected in series to the load loop through the contactor contacts
to keep the load voltage from exceeding the specified value; when the grid voltage drops close to or below 220V, the series
resistor is cut off. The disadvantage of this circuit is that power is consumed in the voltage limiting resistor. In addition, the voltage limiting resistor
can be increased or decreased through switches sl and S2 according to the load size (see dotted box).
The voltage setting value can be adjusted by adjusting the potentiometer RP.
- How about the boost converter TPS61299?
- Recommended circuits for different power on times of LM4911
- Switching power supply circuit composition and function introduction of each part
- Miniature polarity reversal power supply using MAX1721
- Dynamic power supply for power amplifier controlled by thyristor
- A novel and practical DC low voltage stabilized power supply
- Car power 1.5V-12V six-speed converter
- Adjustable voltage power socket
- Production of backup power supply for cordless phone
- Battery powered switching circuit diagram
- Smoking Cessation Circuit
- soil content measurement circuit
- Fish pond oxygenation reminder circuit
- Peanut and melon seeds roasting machine circuit
- Poultry warming temperature control circuit
- Diode balanced amplitude modulation circuit
- Crabo oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- Home appliance repair signal generator circuit
