MAX610 internal structure and pin arrangement
Source: InternetPublisher:刘德华河北分华 Keywords: DC power supply DC regulated power supply voltage regulator tube Updated: 2020/10/29
The MAX610 series AC/ DC power converter is equipped with a rectifier circuit, voltage regulator tube and current limiting protection circuit. The DC stabilized power supply
composed of it has good voltage stabilization performance. Its internal structure and pin arrangement are as shown in the figure
- Schematic diagram of car cigarette lighter to USB power port
- Step-down power supply for driving relays
- Constant current LED lamp driver circuit with soft start and anti-shock
- Detailed explanation of 5v charger circuit diagram
- Low cost and high performance LED constant current power supply
- Current/voltage conversion circuit using current converter
- Boost drive circuit composed of RT8450
- 3~15V 10A adjustable voltage regulated power supply
- The production of adjustable voltage-stabilized power supply composed of LM317
- LM317T voltage regulation adjustable circuit diagram explanation
- Output 12V-10A power supply circuit
- Commonly used power circuits in printers
- 2-phase CPU power supply circuit using HIP6302 and HIP6602 chips
- Computer motherboard power circuit with +5.1V, -5V, +12V and -12V outputs
- Industrial four-way programmable controller power circuit
- Antenna amplifier synchronous power supply circuit
- Common power circuits and applications 03
- Inverter power circuit
- ±5V, ±12V power circuit B
- Maintenance and experiment of multi-purpose power circuits
