Operational amplifier stabilized power supply circuit 4
Source: InternetPublisher:风向双子座 Keywords: Operational amplifier regulated power supply circuit BSP output voltage Updated: 2020/05/28
When the input voltage of this power supply is 280-330V, the output voltage is 280V, the current is
25mA, and the stability is <o. 04%. The output voltage is determined by U∞=Ui (鱼无鱼).
In the figure, the transistor VT is a regulating tube; the operational amplifier A is used as a comparison amplifier circuit; the reference voltage is taken from the voltage regulator tube vsl.
- Basic characteristics of power field effect tubes, how to improve the dynamic performance of power MOSFET
- How about the boost converter TPS61299?
- Benefits of Wide Bandgap Technology for Power Converters
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Driving circuit that controls LED brightness using PWM signal
- Parallel DC regulated power supply circuit diagram
- Principles and precautions of active discharge circuit
- LNK304 non-isolated LED light string driver circuit
- Miniature polarity reversal power supply using MAX1721
- Circuit diagram explanation: simple switching power supply circuit diagram
- High-efficiency speaker circuit for rural stage
- Rice mill circuit
- Straw returning to field crusher circuit
- Poultry warming temperature control circuit
- AC voltmeter
- Varactor Diode Frequency Modulator
- Simple AGC circuit in transistor radio
- Diode balanced amplitude modulation circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Double gate field effect transistor high frequency amplifier circuit
