Single tube series transistor stabilized power supply circuit 2
Source: InternetPublisher:公子李 Keywords: Single tube transistor regulated power supply circuit series type Updated: 2021/09/12
It uses PNP type
triode. It is a commonly used regulated power supply for transistor radios, with an output voltage of 3-15V and a current of 100-500mA.
The output voltage is allowed to fluctuate by 5% to 10% from no load to full load, and the circuit is relatively simple. Select the component parameters according to the required output voltage and
current.
- Redundancy principle of power management system, a redundant design strategy in outdoor power BMS
- How to improve the accuracy and precision of power supplies through low frequency thermal noise?
- In-depth analysis of DC-AC converter inverter
- Practical and convenient fax machine power supply control circuit
- MT3608 constitutes a 3.7V to 12V boost circuit diagram
- Visible laser digital control modulation driver
- How to use SBR to improve power conversion efficiency
- Boost drive circuit composed of RT8450
- A small and easy-to-make fast charger
- Design of electric vehicle charger
- transistor audio mixer
- Design and production of practical and simple transistor adjustable voltage stabilized power supply
- common emitter amplifier circuit
- Tire flat alarm circuit
- Transistor voice control amplifier circuit
- water saving circuit
- Infrared remote control relay circuit a
- Touch switch power circuit
- Series DC regulated power supply
- Single tube rectifier energy consumption braking
