Tire flat alarm circuit
Source: InternetPublisher:偷熊计划 Keywords: Alarm circuit transistor BSP microphone Updated: 2021/05/21
This is the circuit schematic diagram of a bicycle tire leakage detector. The sound of the air flow in the leaking part of the inner tire of the car is received by the microphone BM , converted
into an electrical signal, coupled to the transistor
VT
through the capacitor 6 for amplification, and then passed through the coupling capacitors C3 and C4 and the volume is selected by the potentiometer RP. The power amplifier SL31 is fully amplified and the sound is played by the earphone EJ.
The bicycle tire leakage detector
uses a low-voltage integrated power amplifier circuit
SL31 (or LA4101). Its operating
voltage can be selected between 2 and 4. 5V, and
the current working power supply is 3V. The transistor
VT uses silicon NPN transistor
3DG8, which has low noise and is
helpful for identifying gas rejection faults. The value should be
above 120 and the penetration current J. . Stop if less than
1. Headphones can use 8n low-impedance earplugs.
Electret microphone BM uses non-directional
miniature electret condenser microphone CR22-9B
. The remaining resistors and capacitors are all small
components. The outer shell can be made of transistor small
radio plastic shell, with dimensions of about 68mm×s8mm. The working power supply uses two R-type batteries connected in series. Potentiometer RP is a small synthetic membrane potentiometer
type WH15-K22 with power switch.
- Experiment on realizing photoelectric alarm using photosensitive devices
- Example of LED AC drive circuit
- Musical doorbell without buttons
- Driving circuit for driving light-emitting diodes by IR53HD420
- Desk lamp dimming soft switch circuit
- Mains undervoltage and overvoltage protection circuit 2
- Application circuit of CAT3606
- Fluorescent lamp electronic ballast circuit 11
- Four color light circuit
- Reverse polarity drive circuit
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- Physiotherapy ventilator circuit
- Egg warming circuit
- Egg heating control circuit
- Amplitude modulation circuit composed of MC1496
- Inductive feedback oscillator circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- common emitter amplifier circuit
- Three primary color display circuit
