JK8 proximity switch circuit
Source: InternetPublisher:酷到被通缉 Keywords: Switch circuit proximity switch BSP Updated: 2020/01/08
The proximity switch is a non-contact object detection switch that can be used for various purposes such as alarming. The proximity switch circuit of the JK series proximity switch application-specific integrated circuit , which imitates the Siemens
TCA205 and TCA305 circuits, is shown in Figure 13J165 and Figure
13-166.
When a metal object approaches the induction coil, the JK integrated circuit receives the induction signal , rectifies the oscillation
signal , and transmits it to the driver through the Schmitt circuit. After an appropriate delay, the voltage signal is added to the base of the triode , and make it
conductive, the trigger signal is output from pin 7 of JK , and is input to the control electrode of the bidirectional thyristor V through the bidirectional trigger diode VD,
and makes it conductive, thus turning on the load power supply.
- Circuit diagram of game score display using 7-segment LED
- Six LED stereo VU display circuit built with IC LM3915
- SC3071 touch step dimming light circuit
- One of the bead-type emergency light circuits
- Colorimeter circuit
- Simple light-controlled street light circuit (7)
- SH-803R holiday lights ASIC
- Photoelectric adjustment circuit
- 6-digit cathode fluorescent triode display circuit
- Four color light circuit
- Electronic thermometer circuit
- Peanut and melon seeds roasting machine circuit
- Farmland irrigation automatic control circuit a
- Diode Balanced Mixer Circuit
- Proportional frequency discriminator circuit
- Voltage series negative feedback amplifier circuit
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Fault signal trip circuit
- Motorcycle flash light circuit
