Connection of music alarm detection components
Source: InternetPublisher:武林萌主 Keywords: Alarm BSP alarm circuit Updated: 2021/01/21
If different detection components are added to the alarm circuit , alarms for different purposes can be formed.
Figure 13-44 is a music alarm circuit, using C2875E music
circuit.
If
various detection components as shown in Figure 13-45 are added to the alarm circuit in Figure 13-44 , the following various alarms will be constructed .
Figure 13-45 (a) is for magnetically controlled proximity alarm; Figure (b) is for
magnetically controlled removal alarm; Figure (.c) is for temperature alarm; Figure (d)
is for moisture sensitive alarm; Figure (. e) is for light-controlled alarm; Figure (f) is for sound
-controlled alarm; Figure (g) is for liquid level alarm; Figure (h) is for over-voltage
alarm; Figure (i) is for inductive high-voltage alarm. Alarm distance:
2.5-8m at lOkV high voltage; 5-20cm at 220V mains power.
- DCD-1240 multifunctional rechargeable lighting
- Low cost LED automatic emergency light circuit
- LED Flasher circuit using 2 transistors for LED switching
- Design and production of digital number answering machine
- Lighting lamp voltage stabilizing circuit (2)
- One of the bead-type emergency light circuits
- Gas flameout alarm circuit
- Application circuit of CAT3606
- Economical and practical delay light circuit
- SH-803R holiday lights ASIC
- Set timing circuit when power is on
- Electronic thermometer circuit
- stuttering correction circuit
- Bone hyperplasia treatment circuit
- Homemade disinfectant circuit
- Electronic anti-asthma circuit
- Diode square rate detection circuit
- base amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
