Alarm and protection circuit using operational amplifier
Source: InternetPublisher:3228 Keywords: Protection circuit operational amplifier transistor Updated: 2021/07/17
It uses an operational amplifier and works as a comparator. The detected signal Us can be a voltage converted
from temperature, pressure, humidity, strain and other non-electrical quantities through a transducing element . When U. ,>U. (comparison threshold)
, the transistor VT is turned on, driving the alarm circuit, or the relay controls the action of the protection system.
- One-digit display
- Experiment on realizing photoelectric alarm using photosensitive devices
- USB powered portable light
- Low cost LED automatic emergency light circuit
- Laser detection and indicating device system circuit design
- One of the bead-type emergency light circuits
- Economical and practical delay light circuit
- Automotive LED driver circuit diagram using LT3486
- Incandescent lamp dimming circuit using thyristor part 4a
- Fluorescent lamp dimming circuit composed of thyristors
- 3V-5V level conversion circuit diagram
- H-bridge drive circuit schematic diagram and enable control and direction logic
- Simple transistor relay delay pull-in circuit diagram
- Composite pipe a
- Transistor time relay circuit three
- Transistor common emitter amplifier circuit a
- Soft start regulated power supply circuit three
- One of the over-temperature alarm circuits
- Automatic water supply control circuit 2 for simultaneous monitoring of water tower and reservoir
