Transistor common emitter amplifier circuit a
Source: InternetPublisher:他们逼我做卧底 Keywords: Transistor common emitter amplifier circuit bias circuit static operating point Updated: 2021/10/11
The circuit adopts a bias circuit that automatically stabilizes the static operating point and has good thermal stability. The triode
is of NPN type (Iceo is very small). Adjusting the potentiometer RP can change the static operating point .
Figure (a) uses a voltage-divided emitter bias circuit ;
Figure (b) uses the thermistor R. to compensate for changes in operating point.
- Which one is better, NPN or PNP transistor?
- In-depth analysis of energy losses in oscillation frequencies
- Capacitance detection circuit configuration, how to deal with low frequency and high frequency noise?
- What is the difference between CPLD and FPGA?
- Working principle/characteristics/application fields/equivalent circuit of unijunction transistor
- Causes of PCB deformation How to prevent circuit board bending and warping
- Structural diagram and function of sliding resistor
- What is the difference between high-side and low-side resistive current sensing
- Make a simple AM radio with digital circuit
- Circuit diagram of a differential amplifier circuit
- 3V-5V level conversion circuit diagram
- Transistor time relay circuit 4
- One of the rechargeable time relay circuits
- Three types of transistor amplification circuits and their characteristics - common collector circuit
- One of the regulated power supply circuits with differential amplifier and over-current protection
- Soft start regulated power supply circuit 4
- One of the soft-start regulated power supply circuits
- One of the over-temperature alarm circuits
- output circuit
- One of the electric contact mercury thermometer constant temperature control circuits
