Light-controlled road construction warning light circuit 2
Source: InternetPublisher:萌面大虾 Keywords: Light control type road construction BSP Updated: 2021/02/19
It uses CD4069B six-NOT gate integrated circuit Di~D6, in which Di and D2 form
an ultra-low-frequency oscillator with adjustable frequency (adjusting potentiometer RP), Da serves as an inverter, and D acts as an inverter. ~D6 is connected in parallel as the output controller.
Adjust RP to change the flashing frequency. Photoresistor RG is used as the light control component.
- Making a photometer with light measuring function
- DIY a hat with a programmable LED display
- DCD-1240 multifunctional rechargeable lighting
- Laser detection and indicating device system circuit design
- Design and production of rain control and light control timing controller based on P87LPC764
- Use NE555 to make a lighting and sound changing circuit
- Driving circuit for driving light-emitting diodes by IR53HD420
- AC and DC dual-purpose flash light
- Automotive LED driver circuit diagram using LT3486
- Four color light circuit
- Voice controlled flash LED light circuit diagram
- soil content measurement circuit
- Farmland drainage automatic control circuit
- Farmland irrigation automatic control circuit a
- Domestic KD8041 integrated phase locked loop
- base amplitude modulation circuit
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Voltage controlled power supply second-order high-pass filter circuit
- Color display circuit
- Fault signal trip circuit
