Thyristor-torque motor regulator system block diagram
Source: InternetPublisher:newrudeman Keywords: Thyristor regulator torque motor BSP Updated: 2020/12/08
The electrode automatic regulator adopts bidirectional thyristor torque motor control and
has advanced performance. It has speed measurement negative feedback to form a closed-loop system. The measurement integrator uses an integrated operational amplifier. It has stable operation, high
reliability , high sensitivity, easy adjustment, small dead zone range, small inertia, and no overshoot and tripping. It is debugging and It is easy to maintain
and can significantly save energy and improve product quality.
(1) Thyristor - torque motor regulator system block diagram
- What is a 4-pin PWM header? How do 4-pin PWM fans work?
- Tutorial on making your own remote-controlled robotic arm
- How to set up a cheap beam break sensor control distance scene using a reflector
- Squirrel cage asynchronous motor reverse braking control circuit
- One-way rotation circuit of motor controlled by contactor
- Design and principle analysis of practical electric curtain remote control device
- Audio interface protection circuit
- Amplitude and phase detection leakage protection device designed and manufactured using PIC16C711A
- Delay switch made with LM431
- Bicycle anti-theft alarm
- Fish pond oxygenation reminder circuit
- Chicken supplementary light to increase egg production rate circuit
- Straw returning to field crusher circuit
- Particle clogging alarm circuit of wheat seeder
- Proportional frequency discriminator circuit
- Varactor Diode Frequency Modulator
- collector amplitude modulation circuit
- Parallel crystal oscillator
- Double gate field effect transistor high frequency amplifier circuit
- Voltage series negative feedback amplifier circuit
