Small DC motor irreversible speed regulation circuit 2
Source: InternetPublisher:已注销 Keywords: DC motor reversible speed regulation speed regulation circuit BSP Updated: 2021/06/05
It uses a single thyristor control, the speed adjustment range is 10:1, and the motor power can be
o. Between 8-7.5kW, it is suitable for occasions where the accuracy requirements are not high and the load changes little.
In the figure, L is the filter inductor to limit the rate of change of current.
Adjust the potentiometer RP] to change the amount of voltage negative feedback (stabilize the speed); adjust the master potentiometer RP2 to
change the speed of the motor.
- Analysis of the working principle of the sound and light controlled delay switch circuit
- Car ice warning circuit sharing
- Build a glove-controlled robotic arm
- How to build a simple tachometer using an infrared reflectance sensor
- How to make a wheeled self-balancing robot using ultrasonic sensors
- Introduction to the internal structure of the Delta winding motor
- Motor self-starting circuit
- Infrared blocking alarm device
- Motorcycle anti-theft device circuit design
- Bicycle anti-theft alarm
- Fish pond oxygenation reminder circuit
- Agricultural spraying and insecticide control circuit
- Junction field effect transistor mixer circuit
- Simple AGC circuit in transistor radio
- Parallel crystal oscillator
- Common emitter-common base wideband amplifier circuit composed of F733 integrated amplifier
- Differential Amplifier Circuit
- Home appliance repair signal generator circuit
- Sawtooth wave generator circuit (2)
- Sine wave signal generator circuit
