The module prohibits constant current and constant voltage function port wiring
Source: InternetPublisher:失踪的猫 Keywords: Constant current wiring BSP Updated: 2020/08/21
The module disables the constant current and constant voltage function port wiring.
In the figure, pin 13; OFF, the constant current and constant voltage disable port . When OFF and grounded, the constant current and constant voltage function is lost, and the module only has
the phase shift control function.
- Analysis of the working principle of car garage door lights
- The meaning and importance of circuit protection, common types of circuit protection
- Tutorial on making your own remote-controlled robotic arm
- How to remotely control devices using ESP8266 and LPC2148
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Manual automatic air compressor control circuit
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Ultra-short wave item left behind reminder alarm
- Water supply reminder after water outage
- Self-defense anti-riot circuit
- Electronic thermometer circuit
- Diode balanced amplitude modulation circuit
- Audio function generator composed of ICL8038
- Capacitive feedback oscillator circuit
- Multi-frequency resonant high-frequency power amplifier circuit for transmitter stage
- Voltage-controlled voltage source second-order band-pass filter circuit
- Voltage-controlled voltage source second-order active low-pass filter circuit
- Fault signal trip circuit
- Sawtooth wave generator circuit (1)
