Home > Control Circuits > Zero trigger thyristor temperature control circuit 3
Source: InternetPublisher:smallembedded Keywords: Thyristor trigger temperature control circuit BSP Updated: 2021/10/23
82. Zero<strong>Trigger</strong> Type<strong>Thyristor</strong><strong>Temperature Control Circuit</strong>Part 3.gif
It uses TA7606P integrated circuit (zero voltage control switch). The temperature control range is
between 30-70℃, and the accuracy is ±2℃. The temperature measuring element is a thermistor R with negative temperature coefficient. .
    The measuring bridge is composed of resistor, potentiometer RP, thermistor and the resistance inside the integrated circuit A.
The output signal is sent out by detecting the balance of the bridge. The temperature set value is adjusted by the potentiometer RP.
