Temperature switch circuit three
Source: InternetPublisher:风向西瓜 Keywords: Switching circuit BSP automotive air conditioner Updated: 2020/05/05
It is the electronic thermostat circuit on an imported car air conditioner . The operational amplifiers Ai and A2 adopt LM393.
Adjust potentiometer RP. The temperature control range can be changed. The adjustment range is: startup temperature 6~18℃, shutdown temperature 3~
15℃, and the temperature difference between startup and shutdown is 3℃.
Negative temperature coefficient thermistor R. You can choose RR03-2 type, the resistance value is 3k, Q at 25℃, or MF51 type.
- Model rocket launch controller circuit
- How to Build a Gesture-Controlled Elevator Prototype Using Arduino Nano
- Perform surgery on the speaker protection circuit
- Design and principle analysis of practical electric curtain remote control device
- Design and analysis of touch delay switch circuit composed of CD4011 and CD4001
- Temperature control circuit design and analysis
- Design and manufacture of three-phase motor protection circuit
- Audio interface protection circuit
- Water supply reminder after water outage
- Precious home appliance anti-theft alarm
- Egg heating control circuit
- Diode balanced amplitude modulation circuit
- Audio function generator composed of ICL8038
- Differential Amplifier Circuit
- Second-order active band-stop filter circuit
- Voltage controlled power supply second-order high-pass filter circuit
- Color display circuit
- Guest arrival signal recognition circuit
- Digital stopwatch display circuit
- Sawtooth wave generator circuit (2)
