One of the high-precision non-contact temperature control circuits
Source: InternetPublisher:supremeOne Keywords: No contact high precision temperature control circuit BSP Updated: 2021/10/08
When the temperature sensing element R. When using platinum resistor WZB-010, the temperature control range can be from room temperature
to 300℃.
The main circuit is a bidirectional thyristor V AC voltage regulating circuit. The trigger circuit is a relaxation
oscillator composed of single-junction transistors VTs, etc. Among them, transistor VT4 is used as a variable resistor. A differential amplifier is composed of transistors VTi and VT2. The input
signal of the amplifier is the potential difference between the diagonal lines A and B of the bridge composed of resistors R7 and R8, potentiometer RP, and platinum resistor R. This potential
difference controls the conduction degree of VT4, thereby changing the output pulse of the single-junction transistor trigger circuit and changing the conduction angle of V to achieve
the purpose of automatic constant temperature control.
- Current output characteristics of brushed motor driver chips. How to increase the peak drive current?
- Design of an autonomous plant watering system using ATtiny85
- How to build a simple tachometer using an infrared reflectance sensor
- How to Make a Simple Chicken Incubator
- What is a RADAX motor?
- Replace the GE LOGIQ a200 ultrasound measurement key with a self-made touch switch
- Working principle of ZNB-S digital display intelligent motor protector control circuit
- Temperature control circuit design and analysis
- Do-it-yourself trial production of phase failure protection device
- Home wireless burglar alarm circuit
- Excellent performance household inverter power supply circuit
- High-efficiency speaker circuit for rural stage
- Poultry warming temperature control circuit
- DC ammeter
- Diode square rate detection circuit
- collector amplitude modulation circuit
- ring amplitude modulation circuit
- Differential Amplifier Circuit
- common emitter amplifier circuit
- Color display circuit
