One of the thermostatic control circuits using operational amplifiers c
Source: InternetPublisher:张七岁 Keywords: Operational amplifier thermostatic control circuit BSP Updated: 2020/01/24
The constant temperature control circuit using operational amplifier as the control element has high temperature control accuracy and stable performance.
The circuit is shown in Figure 11-46. These three circuits all use operational amplifier A as the control element and the thermistor R.
#Temperature sensing element . The difference is that the power supply part in Figure 11-46 (a) is the simplest, using a capacitor to reduce the voltage, eliminating a transformer;
Figure 11-46 (b) uses a transformer to reduce the voltage; Figure 11-46 (c) uses a transformer to reduce the voltage And series type regulated power supply,
with better voltage stability. In addition, Figure 11-46 (a) and Figure 11-46 (b) directly control the triac to heat the electric heater, while Figure 11
6 (c) controls the electric heater through the relay KA. The working principles of these three circuits are basically the same.
The thermistor Rt, together with the resistor Rz and the potentiometer RP, provide a comparison voltage for the operational amplifier A.
Thermistor Rt can be selected from MF11 type or MF53 type, lOkfl, 0.25W.
- Controlling LEDs with Multithreading via Dual-Core Programming on Raspberry Pi using MicroPython
- How to Build a Touch-Based Color-Changing Plant Using Arduino
- A small improvement on the ordinary refrigerator motor starting circuit
- IGBT modules block overcurrent by controlling the gate
- Hydraulic control circuit design and analysis
- Design and production of wireless multi-location control switch circuit
- Do-it-yourself trial production of phase failure protection device
- Design and production of no-load automatic power-off device for household power supply
- Motorcycle anti-theft device circuit design
- Precious home appliance anti-theft alarm
- Set timing circuit when power is on
- Self-defense anti-riot circuit
- AC voltmeter
- Domestic KD8041 integrated phase locked loop
- Diode balanced amplitude modulation circuit
- Audio function generator composed of ICL8038
- Wien bridge oscillator circuit
- Voltage series negative feedback amplifier circuit
- common emitter amplifier circuit
- Power phase sequence display circuit
